joshhaleaos
Beginner
CUCM 8.5 Upgrade - EM
Client is upgrading from 8.0.3 on MCS to 8.5 on UCS.  I know that I must disable EM when upgrading but does the DRS backup retain their current logged in phone or will they have to login again?
Thanks!
1 ACCEPTED SOLUTION
Marwan ALshawi
Advisor
As long as there is upgrade then the phones will perform firmware upgrade when register with new cm and then the EM login will be required
Hope this help
If helpful rate
1 REPLY 1
Marwan ALshawi
Advisor
Hope this help
If helpful rate
Content for Community-Ad
Spotlight Awards 2021
