CUCM 8.6.1(a) licensing question
ulambaday
Hi All,
We have 1 pub and 3 sub. We added a new subscriber to our CUCM cluster but we didnt had the node licenses. Then we got a temp license from Cisco
We added those licenses to our CUCM pub but still we see the node license is not activated
Units authorized: 5
Units used : 4
Units remaining: 1
I am not sure if we have to restart just CM services to activate it  or restart Pub and subs??
Any help is much appreciated
Thanks in advance
13 Replies 13
Chris Deren
Correct, you will see it used once you start the CM service.
Chris
Thanks Chris.
So, we will have to restart only Pub CM service??
Chris Deren
No need to restart anything, simply activate the service.
I did restart CM service on Pub but I still see units used 4.
Units authorized: 5
Units used : 4
Units remaining: 1
Not sure why it is not taking the node license
Chris Deren
Is CM service activated on all 5 servers?
CM service is activated on all 4 servers, but not on the newly added subscriber.
When we try to activate the CM service on new sub, we are getting this error
pdate Failed for the Service(s): Cisco CallManager Service cannot be Activated or Deactivated due to Database Update Failure.
Chris Deren
Check your database replication, this has nothing to do with licensing.
can u share old lic file and new lic file provided by Cisco?
also , share the output of utils dbreplication runtimestate from Publisher.
regds,
aman
Hi All,
I opened a TAC case to work on this issue and came to know that it is a known issue, TAC gave me a python script to upload on all servers. I ran that script through root access and the issue got fixed.
Once we activated the services on CUCM sub, it consumed one node license.
Thanks for all your help!!!
thanks for update.
Did u ever change the security password on Publisher before installing the new Subscriber?
regds,
aman
Hi Aman,
I forgot to mention in my last update, yes we changed the security password on all servers.So to sync all db passwords, we had to run that script.
Uday
This issue is for a caveat when you change the Security Password and passwords are not sincronized locally.
Your problem was due to these bugs
DB service is down, after changing the security password.
CSCth87452
CLI "set password user security" did not set the correct apps password
CSCua09290
regds,
aman
