05-29-2013 02:44 AM - edited 03-16-2019 05:34 PM
Dear All,
I'm planning to upgrade CUCM from version 8.6.2.20000-2 to SU3 and my question is do i need to use the COP file named ciscocm.refresh_upgrade_v1.1.cop.sgn.
Thank you,
Solved! Go to Solution.
05-29-2013 03:16 AM
Hi Valdet,
My apologizes , I looked into old compatibility matrix.
In your case for upgrading from 8.6.2.20000-2 to unrestricted 8.6.2.23900-10 , u do not require any refresh upgrade patch.
regds,
aman
05-29-2013 02:58 AM
Hi Valdet,
The current CUCM version u are using is 8.6.2.20000-2 [8.6(2a)] and upgraded version which is available is 8.6(2a)SU2[8.6.2.22900-9] not SU3.
Can u please re-check which Unrestricted version u want to upgrade?
If u want to upgrade to 8.6(2a) SU2 , then, u do not require above refresh_ upgrade file.
regds,
aman
05-29-2013 03:05 AM
Hi Amanso,
The unrestricted version is Release 8.6(2a)SU3 published on May 13. Here is the link:
05-29-2013 03:16 AM
Hi Valdet,
regds,
aman
