03-18-2013 02:15 PM - edited 03-16-2019 04:19 PM
Good morming §I' ve the problem in object.
I've a ciscp cucm 8.6.2 and cisco cue 8.6. I've correctly configured the cti ports (and it have correctly registered) I've confogured the cti route point but they want register (the registration status in " unknown). the cti port and the cti route poing are correctly associated to jtapiuser. I need help (i possible.
I've restarder the cti manager service but the problem was not solved, for that after I've restarted completely The callmanager .
But the problem was not solved.
Can you help me????
Solved! Go to Solution.
03-18-2013 03:04 PM
can you make sure that you can ping the CUE from the callmanager. did you change your administrator password for callmanager recently. if yes, you need to update the password on unity express
Anas
please rate if it is helpful
03-18-2013 03:20 PM
03-19-2013 03:43 AM
kindly don't forget to rate the helpful post. this will help the community
your issue is related to sip dial-peer which pointing to CUE. This dial-peer should point to the callmanager as a first priority because it is associated via JTAPI, the 2nd priority could be pointed to the unity express for SRST.
if you can share the dial-peer it will be better.
Anas
03-18-2013 03:04 PM
Anas
03-18-2013 03:13 PM
Hi Anas. The cm pinging coerrectly the cue and I'havn change the password.
The cti port are correctly registered on te cucm,
The cti route point are not registereds on the cucm
03-18-2013 03:19 PM
try to reset the CTI port, deassociate it from JTAPI user and associate it again.
Anas
03-18-2013 03:20 PM
is jtapi user added to standard cti enabled
Haitham
03-19-2013 03:28 AM
Ok thanks now the cti route point it's correctlky registered. but if I call the internal number (576 of cti route poient) the number is always busy?
Can you halp me to solve this new problem?
03-19-2013 03:43 AM
Anas
