CUCM 8.6.2 VMTools
vicky.canavesi
Hi all,
I tried to install VMTools on CUCM 8.6.2 as indicated at:
http://docwiki.cisco.com/wiki/VMware_Tools#Which_method_to_use
Now from ESXi GUI interface I can see VMTools status OK, but if I type "utils vmtools status" on cli the system say:
admin:utils vmtools status
No VMware Tools tarball found on the install media.
Please ensure that you have selected
Guest -> Install/Upgrade VMware Tools by right-clicking on the
VM from your VI client.
Can someone indicate wich is the correct status of vmtools ?
Vittorio
Aaron Harrison
It looks like the command is trying to compare the VMtools that are installed to the VMtools on the media. If you do the right click/install vmtools on the virtual machine in vSphere and then run the command again does it give you a better response?
If vSphere says it's OK, then it's OK is pretty much the bottom line either way.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
