Highlighted
Frequent Contributor
CUCM 8.6.2 - Warning message when open CAR
Hi Guys,
When the Customer open the CAR appear the message "Previous Migration Failed. Click here to see the logs". After close this windows, I verified that the report is generated, but, I don´t have sure that the information that was generated in report is correct.
Wilson
Everyone's tags (7)
1 REPLY 1
Highlighted
Enthusiast
My recomendation would be for you to open a case with TAC for investigation under this bug. You might consider the reports are working properly but there might be a hidden issue with your CDR. This culprit we are aware of is the following.
CSCtt17946
Unable to run CDR reports after upgrade due to "Migration in progress"
