CUCM 8.6 and CRM integration, which API or XML service?
skirk1983
Hi there
I have been asked to find documentation about CUCM developer interface. We would like our CRM system to connect to CUCM and receive CID/CTI and call duration in real-time for a start.
Which way should we look? Do our CRM supplier have to look at AXL interface, or Serviceability XML for real-time call data? or in another way? any suggestions?
Kristian
Jonathan Schulenberg
Real-time data would require the TSP which provides a TAPI or JTAPI interface for subscribing to devices/DNs via CTI Manager. Both of the XML interfaces you mentioned are for administrative functions. CTI applications can impact the scalability of the CUCM cluster so plan accordingly.
Please remember to rate helpful responses and identify helpful or correct answers.
Thanks for the info Jonathan
