CUCM 8.6 - Certificate expiration Notification
Chris Bailey
I'm getting alerts that these certs are expiring on our CUCM cluster (1 pub 1 sub)
We are running CUCM 8.6 Cluster Security Mode is set to 0
Is it as simple as hitting regenerate for each cert in OS administration or do we need to do this in a certain order?
I found some guide online which mentions rebooting phones so ITL file can be updated - is this still required if running in non secure mode?
Alarm to indicate that Certificate has Expired or Expires in less than seven days:
Unit:CallManager Type:own-cert Expiration
Unit:tomcat Type:own-cert Expiration
Unit:CAPF Type:own-cert Expiration
Unit:ipsec Type:own-cert Expiration
Unit:TVS Type:own-cert Expiration
Unit:CAPF-trust Type:own-cert
Unit:tomcat-trust Type:own-cert
Unit:CallManager-trust Type:own-cert
Unit:ipsec-trust Type:own-cert
Leszek Wojnarski
Hi Chris,
Please refer to:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200199-CUCM-Certificate-Regeneration-Renewal-Pr.html
When it comes to phones restart:
"Caution: Regenerations of certificates triggers an automatic update of the ITL files within the cluster, which triggers a cluster-wide soft phone reset to allow phones to trigger an update of their local ITL. This is focused on CAPF and CallManager certificate regenerations, but can occur with other certificate stores within CUCM, such as Tomcat."
Leszek
Thanks for the replies.
is it important to also delete the expiring certificates after we have regenerated the new ones?
If you don't then you will be getting alerts, but leaving those expired certs will not break anything.
Leszek
Jaime Valencia
Unless you use the prepare rollback parameter, ITL is always in use since 8.x, and that is completely independent of whether you're using a secure cluster, or not. Thus the name of SBD (security by default).
Read very carefully the doc Leszek provided, as not following the right order, or doing all the servers/certificates at the same time, will cause all of your phones to have ITL mismatch and they will require you to delete the ITL file for them to work again.
java
if this helps, please rate
