Cisco Community Designated VIP Class of 2020
36
Beginner
CUCM 8.6 customiz softkey for dailing to helpdesk
I want to use a softkey as a speed dial to their help desk. has anyone used the Softkey and not a button to do this. if so how?
Yangfeibo
3 REPLIES 3
Engager
AFAIK, speed dial can't be
AFAIK, speed dial can't be configured as softkey.
- Vivek
Well... as softkey you can
Well... as softkey you can configure Abbreviated dial feature.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hall of Fame Cisco Employee
Go to the softkey template
Go to the softkey template config, the options you see, are the options you get, nothing else.
The answer is that what you're asking is not possible.
java
if this helps, please rate
Content for Community-Ad
FusionCharts will render here
