09-29-2014 10:25 AM - edited 03-17-2019 12:19 AM
Dear al
i have PUB & SUB CUCM 8.6 version on UCS plateform due to power failure in data center both the servers got illegally shutdown after restoring the power we restarted both the server after checking the service list " A Cisco DB[STOPPED] Component is not running" & while logging through GUI it is prompting DB communication error in PUB but on SUB all the services are in starting state. please advice how to rectify the same.
09-29-2014 10:46 AM
Try to restart your A cisco DB service via following CLI :
utils service start A Cisco DB
If it is still not starting, most likely, file system/DB has been corrupted due to improper power down of the server. You can try to Use recovery CD and check if that helps, else the last option would be to rebuild and do a DRS restore, from backup before the power down or using "Restore from Sub" option.
Aditya
09-29-2014 01:34 PM
hi Aditya tried to restart services & used recovery cd but no luck i think i need to rebuild the server. or check with cisco TAC
09-29-2014 01:37 PM
You can check with TAC , they might be able to help you out. Rebuilding will any how be the last option.
Incase you don't have a valid backup, you can always restore database from sub to pub, but there is is a specific procedure to that.
09-29-2014 12:19 PM
Check out similar recent thread:
https://supportforums.cisco.com/discussion/12311996/emergency-major-power-failure-publisher-subscriber-connection-wont-start
Chris
09-29-2014 01:31 PM
Thanks Chris tired all possibilities but no luck. the major challenge is that i dont have backup
09-29-2014 01:36 PM
If you follow that thread you will see that the possibilities are to rebuild as I needed to. If you have no backup or working sub where you could follow this:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116946-technote-product-00.html#anc14
then I hate to say it, but you may be rebuilding from scratch.
Chris
