8237
ronin2k8cronus
Beginner
CUCM 8.6 db sync problem
Hi guys,
I have a problem with my CUCM cluster. It is a 8.6 cluster with a pub and one sub. It is a cluster over the wan (vpn between locations). Untill a couple of days ago everything was fine. In the meantime a router that was tacking care of the connections between the two locations stopped working and was replaced about an hour later with another one.
The problem is that now the cluster has some big problems. The two servers are able to ping each other but it seems that the Pub can not connect to the sub DB anymore.
In the attached doc you can find more info, out of which I extracted a few data below:
PUBLISHER:
admin:
admin:show tech network hosts
-------------------- show platform network --------------------
/etc/hosts File:
#This file was generated by the /etc/hosts cluster manager.
#It is automatically updated as nodes are added, changed, removed from the cluster.
127.0.0.1 localhost
::1 localhost
10.1.55.5 CMP
10.1.157.6 CMS
admin:utils diagnose module validate_network
Log file: platform/log/diag2.log
Starting diagnostic test(s)
test - validate_network   : Passed
Diagnostics Completed
admin:show network cluster
10.1.55.5 cmp Publisher not authenticated - INITIATOR since Wed Jul 25 15:47:18 2012
10.1.157.6 cms Subscriber authenticated
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Only available on the PUB
DB Version: ccm8_6_1_20000_1
Number of replicated tables: 0
Cluster Detailed View from SUB (2 Servers):
                               PING           REPLICATION     REPL.   DBver& REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS     (msec) RPC?   STATUS         QUEUE   TABLES LOOP?   (RTMT)
CMP                      10.1.55.5       1.35              No     Off-Line       N/A     ?       No     (?)
CMS                       10.1.157.6     0.048           Yes     Off-Line       N/A     match   Yes     (0)
System Reports :
Unified CM Database Access
Local and publisher databases   accessible.
View Details
Server
Publisher   DB Reachable
Local   DB Reachable
10.1.55.5
true
true
10.1.157.6
true
true
Unified CM Database Status
RTMT Counter Information
Connection to RTMT on 10.1.157.6   could not be established
All servers have a replication   count of 541.
Not all servers have a good   replication status. See the details.
View Details
Server
Number   of Replicates Created
Replicate_State
10.1.55.5
541
3 - bad
10.1.157.6
N/A
N/A
See also Database Summary Screen   in RTMT.
Run CLI command (show tech   dbstateinfo) for more detail.
Replication Server List (cdr list   serv) from every server for debugging purposes only.
View Details
Server
cdr   list serv
10.1.55.5
SERVER                   ID STATE   STATUS     QUEUE   CONNECTION CHANGED
g_cmp_ccm8_6_1_20000_1     2 Active   Local           0
10.1.157.6
Replication Server Template (cdr   list template) from every server for debugging purposes only.
View Details
Database Prefs File
View Details
Unified CM Hosts
All servers have equivalent host   files
View Details
Server
Host   Information
10.1.55.5
127.0.0.1 localhost
::1 localhost
10.1.55.5 CMP
10.1.157.6 CMS
10.1.157.6
127.0.0.1 localhost
::1 localhost
10.1.55.5 CMP
10.1.157.6 CMS
Unified CM Rhosts
All servers have equivalent rhosts   files.
View Details
Server
rhosts   File
10.1.55.5
localhost
CMS
CMP
10.1.157.6
localhost
CMP
CMS
Unified CM Sqlhosts
All servers have equivalent   sqlhosts files.
View Details
Server
sqlhosts   File
10.1.55.5
g_hdr   group   -       -       i=1
g_cmp_ccm8_6_1_20000_1 group   -       -       i=2
cmp_ccm8_6_1_20000_1   onsoctcp       10.1.55.5      cmp_ccm8_6_1_20000_1        g=g_cmp_ccm8_6_1_20000_1   b=32767,rto=300
g_cms_ccm8_6_1_20000_1 group   -       -       i=3
cms_ccm8_6_1_20000_1   onsoctcp       10.1.157.6     cms_ccm8_6_1_20000_1        g=g_cms_ccm8_6_1_20000_1   b=32767,rto=300
###NOTE: Need to use ipv4 address in host column of   sqlhosts file and not hostname
cmp_car8_6_1_20000_1   onsoctcp       10.1.55.5      cmp_car8_6_1_20000_1   b=32767
10.1.157.6
g_hdr   group   -       -       i=1
Please help. I read a lot about the subject, but could not reach a solution.
Thank you.
6 REPLIES 6
Chris Deren
Hall of Fame Master
I don't think splitting cluster across VPN is supported, so I would definitely try to mitigate that.
Here is a great doc on troubleshooting and resolving DB replication issues:
https://supportforums.cisco.com/docs/DOC-13672
HTH,
Chris
I read the document and tried the solutions suggested in there but they did not fix my problem.
In my case the Pub can't connect to the Sub although it seems to know it exist and can ping it.
Pub cli:
Cluster Replication State: REPLICATION RESET all Started at 2012-07-25-16-41
Number of replicated tables: 541
Cluster Detailed View from PUB (2 Servers):
SERVER-NAME     IP ADDRESS     (msec) RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
CMP                    10.1.55.5              0.044   Yes     Connected       0       match   Yes     (3) PUB
CMS                    10.1.157.6            1.28      No      Off-Line        N/A     ?       No      (?) N/A
10.1.157.6 cms Subscriber not authenticated - INITIATOR since Wed Jul 25 15:51:16 2012
10.1.55.5 cmp Publisher authenticated
admin:run sql select name,node id from process node
The specified table (process) is not in the database.
Similar output on the Sub.
It worked over the WAN connection (actually is a tunnel with crypto maps). Could this be the problem? Pub can not connect to the Sub because of some network problem although utils diagnose module validate_network says it is ok?
I am thinking about deleting the sbscriber and then adding it again. Is there a procedure for that.
Thank you for your help.
Silviu.
hi ronin,
can you resolve this issues???.....i am having the same problem with the same scenario, my connections of wan goes through ipsec vpn (asa8.2.5---asa8.2.5) and my cucm cluster show the same error on replication runtime command and all them.
please i need urgent help.
As I recall I did nothing to the CUCMs. The problem was the network.
The problem is that the packets sent by the CUCM are too large (close to 1500) and the network needs to fragment them but you problebly do not have the df bit set to 0.
I see three solutions to your problem (try to see if one matches your requirements):
1) stop using ipsec (and since you will lose the added overhead the packets will not need to be fragmented anymore so the CUCM will see each other ok)
2) fragment the packets & adjust the mss to a lower value
route-map DF-BIT permit 10
match ip address 1455
set ip df 0
interface GigabitEthernet0/1.157
description == The Subinterface on which you can find the Sub which is in a different location than the Pub ==
encapsulation dot1Q 157
ip address x y
ip tcp adjust-mss 1300
ip policy route-map DF-BIT
3) When you install a CUCM, the installer will ask you at a certain point to set the MTU, so set it to a lower value (so you must reinstall the sub that is causing problems). I think this is the recommended path.
This sounds like a trial and error mechanism, so my recommendation is try to involve TAC because I am sure they hit this problem many times and they will probably  give you a fast and correct response to your problem.
Hope this helps,
Silviu.
Harmit Singh
Hello all,
Please take a look at the blog and video I posted on dbreplication runtimestate:
Blog url: https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony/blog/2012/10/26/understanding-cucm-dbreplication-runtimestate
Please feel free to provide your feedback and any additional questions you may have on this topic.
Harmit.
Hey guys,
I have faced the same problem in my Cluster. But the only difference is that replication is good in the reports.
But the message on sqlhosts File appear as mentioned:
/etc/hosts File:
127.0.0.1 localhost
::1 localhost
10.0.55.194  BRDC1CUP0003
10.0.55.196 BRDC1CUP0001.name BRDC1CUP0001
10.0.55.197  BRDC1CUP0002
10.0.55.195  BRDC1CUP0004
10.0.55.194 brdc1cup0003  Publisher authenticated
10.0.55.196 brdc1cup0001.name brdc1cup0001 Subscriber authenticated using UDP since Tue May 28 09:43:14 2013
10.0.55.197 brdc1cup0002  Subscriber authenticated using UDP since Tue May 28 09:43:14 2013
10.0.55.195 brdc1cup0004  Subscriber authenticated using TCP since Tue May 28 09:49:28 2013
Cluster Replication State: Replication status command started at: 2013-05-28-10-11
     Replication status command COMPLETED 541 tables checked out of 541
     No Errors or Mismatches found.
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_05_28_10_11_29.out' to see the details
DB Version: ccm8_6_2_20000_2
BRDC1CUP0003    10.0.55.194     0.075   Yes     Connected       0       match   Yes     (2) PUB Setup Completed
BRDC1CUP0004    10.0.55.195     0.269   Yes     Connected       0       match   Yes     (2) Setup Completed
Servercdr list serv
10.0.55.194
g_brdc1cup0003_ccm8_6_2_20000_2    2 Active   Local           0
g_brdc1cup0004_ccm8_6_2_20000_2    3 Active   Connected       0 May 28 09:49:30
10.0.55.195
g_brdc1cup0003_ccm8_6_2_20000_2    2 Active   Connected       0 May 28 09:49:30
g_brdc1cup0004_ccm8_6_2_20000_2    3 Active   Local           0
Serversqlhosts File
10.0.55.194
g_hdr     group     -     -     i=1
g_brdc1cup0003_ccm8_6_2_20000_2     group     -     -     i=2
brdc1cup0003_ccm8_6_2_20000_2     onsoctcp     10.0.55.194     brdc1cup0003_ccm8_6_2_20000_2     g=g_brdc1cup0003_ccm8_6_2_20000_2 b=32767,rto=300
g_brdc1cup0004_ccm8_6_2_20000_2     group     -     -     i=3
brdc1cup0004_ccm8_6_2_20000_2     onsoctcp     10.0.55.195     brdc1cup0004_ccm8_6_2_20000_2     g=g_brdc1cup0004_ccm8_6_2_20000_2 b=32767,rto=300
brdc1cup0003_car8_6_2_20000_2     onsoctcp     10.0.55.194     brdc1cup0003_car8_6_2_20000_2     b=32767
10.0.55.195
g_hdr     group     -     -     i=1
Daniel Sobrinho
Content for Community-Ad
