CUCM 8.6 DRS Backup
bobby.jacob
Hello all,
I was trying to do a backup for CUCM Cluster, when try  to configure Backup device from CUCM DRS Page, its shows "Update failed : Unable to access SFTP server. Please verify SFTP permissions.
The SFTP tool is freeftpd, iam able to take the backup of CUPS with the same SFTP client and PC.
CUCM is 8.6.2 Unrest.
Does anyone came across this issue?
Tnx
Bobby
6 Replies 6
Guru Mysoruu
Are you able to ping the sftp server from the cucm ping tool.
Hi Gurudath,
Ys iam able to ping SFTP Server from CUCM> OS Admin> Ping
Bobby
Was it working before??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime,
We had succesful backups before. DRF Service are up.
tnx
Try deleting the backup device and see if that works
java
vemanyam
share DRF logs
