817
Highlighted
Beginner
CUCM 8.6 Fax
We have cucm 8.6 with sip trunk to ISP. We use Cisco ATA 187 and fax machines to send/receive faxes. We have about 4-5 faxes.
We need solution to send/receive faxes via email.
Do you know easy way to do it?
Everyone's tags (2)
4 REPLIES 4
CUCM 8.6 Fax
Hi Lasha.
From Imagicle Stone fax is a good IP Fax Server.
http://www.imagicle.com/products/collaboration/faxserverip/stonefax/tabid/222/language/en-us/default.aspx
Otherwise you can go with free customized solutions such as asterisk which can act as IP fax server.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Beginner
CUCM 8.6 Fax
Thanks for reply Carlo
Can you tell me details about asterisk fax server? How can I use asterisk fax with cucm?
CUCM 8.6 Fax
Hi Lasha.
You can refer to the following link to have an idea on how it works.
http://www.voip-info.org/wiki/view/Asterisk+fax
You can integrate it through a sip trunk making specific route patterns pointing to it.
Carlo
CUCM 8.6 Fax
also, try to take a look at 2Ring's solution called BUSINESS FAX.
T.38/G.711 protocols are obviously supported.
Get more at http://www.2ring.com/netfax
Martin
Content for Community-Ad
August's Community Spotlight Awards
