CUCM 8 :The onconfig.ccm file error
K D
Beginner
Beginner
Hi ,
I have just finished building a CUCM 8.0.3(a) Cluster.  The database replication is all good. I am left with this particular error.
ErrorThe onconfig.ccm file on 172.22.4.82 does not match the publisher.
ErrorThe onconfig.ccm file on 172.25.4.81 does not match the publisher.
I have restarted the pub as well both subscribers, but still come up with this error. this is an install on UCS blade.
Any idea of what this error might be?
Joseph Martini
There are a bunch of bugs for reporting issues with the onconfig.ccm file, here's one that's not fixed in your CUCM versions CSCtf50227.
8 Replies 8
Joseph Martini
Thanks, Hope is no performance issue.
Nope it's just cosmetic.
I actually recently upgraded to get around this, but it introduced another problem...
https://supportforums.cisco.com/thread/2113221?tstart=0
Just something to be aware of if you are going to upgrade.
bad link
Hi Joe,
I am getting the same error on CUCM - 8.6.2.20000-2. Does that mean that the bug is still not being fixed?
Joseph Chirayath
Danilo Molini
Beginner
Beginner
Hi all,
same error on CUCM 9.0.1.10000-37.
Regards.
Danilo Molini
Hi all,
same error on CUCM 9.1.1.2000-5.
Regards.
Christian Parvex
Recognize Your Peers
