CUCM 8.x and Asterisk
Jean Lofrano
Hi Voice Team,
I did a trunk betweeen my CUCM 8.5 and Asterisk, but it is not working properly.
The Asterisk phones has sucess to call CUCM ip phones, but CUCM ip phones can not to call asterisk phones..
CUCM >>>> Asterisk (Not Working)
Asterisk >>> CUCM (Work! )
Thanks.
Hi Jean,
May I know how do you configure CUCM and Asterisk to achive that?
I have encountered a problem when try to integarte CUCM 8.5 with Asterisk using SIP trunk.
CUCM -> Asterisk (not working)
Asterisk -> CUCM (error 399: Unable to find a device handler for the request received on port 5060)
For your info, I have changed the "outgoing transport type" to UDP.
Thank you.
Alex
Jean Lofrano
Hello!!!
In flow  CUCM >>>>> Asterisk:
I can to hear the user of the another side, but he is not hearing me...
thanks.
I have changed the "outgoing transport type" to UDP and the Asterisk was with problems of the route back.
thanks all.
Hi Jean,
Thank you.
Alex
Not sure whether you've sorted this yet Alex, but make sure the device pool on your SIP trunk contains a Call Manager group with the CUCM server acting as the SIP end point ( configured in Asterix )  and is the primary server in the CUCM group.
Regards.
Ross
