330
elijah.walsh
Beginner
CUCM 9.0.1 MOH Not Working
Using default MOH on the publisher setting sample audio source on Device/Line URI does not work.  Originally began by installing a new MOH Audio Source and none of the servers are registered.  Can not use Multicast and all settings are correct.  MOH still does not work between devices.
2 REPLIES 2
Gergely Szabo
Advocate
Hi, can you double check your services. Is the IP Voice Media Streaming service activated nd running?
G.
moataz_mamdouh
Beginner
Check the device pool of the moh sever and the phone and make sure they are using g711 , unless you specify all codec under the service parameter
Create
Recognize Your Peers
Content for Community-Ad
