09-10-2012 04:29 AM - edited 03-16-2019 01:07 PM
I have downloaded tha ISO for CUCM 9.0.1 from e-delivery but it seems to be a bit bigger than a normal 4,7GB DVD so I cannot burn it. Anyone having the same problem?
Stoyan
09-10-2012 06:40 AM
Why burn it, who uses DVDs these days :-)
Use SFTP to upload it to the server.
Chris
09-10-2012 07:02 AM
Hi Chris,
It is a unsigned ISO so I can only burn it.
09-11-2012 12:00 AM
If you're doing an upgrade, the installer will read the ISO fine.
If you're doing a fresh install, just point VMWare, or the server's management card at the ISO.
As Chris said, DVDs are so last decade ;-)
GTG
09-11-2012 03:44 AM
Somewhere around version 8.5 or 8.6 the images grew larger than a single layer DVD and now require a dual layer DVD if yout want to burn it. This also requires a DVD-ROM that can read dual layer discs too.
09-11-2012 04:02 AM
Apperantly that's how it is. The strange thing is that the CUCM 9.0 image from e-delivery was originally named
UCSInstall_UCOS_9.0.1.10000-37.iso. This way providing it via tftp to CUCM fails as it is not signed. When I renamed it to
UCSInstall_UCOS_9.0.1.10000-37.sgn.iso CUCM accepted it and performed the upgrade.
Stoyan
01-28-2013 05:32 AM
Hi All,
Where Can I download a ISO file version 9.0(2) or higher for a be6k ?
Philippe
03-15-2016 01:37 AM
Dear Stoyan
Could you please help me where can I find the ISO for CUCM 9.x or later.
Best Regards
Alcidio Tembe
03-15-2016 01:47 AM
