CUCM 9.0
tconnorbok
What gateways are support in this call manager rls?  I am needing to know if the 3640 and 3745 routers are supported. Thanks
Both models are still present on gateway list on CUCM 9.1 version
Carlo
Please rate all helpful posts "The more you help the more you learn"
5 Replies 5
Hi.
Both models are pretty old :) anyway they can be added as H323 gateway to CUCM which still supports that signaling protocol.
Carlo
How about as a MGCP gateway?
Carlo
Thank you very much.
Plus 5
Regards, Mohamed Helmy
