Hello, i use a cucm 9.1.1a cluster and try to configure DVO.
1st i configured a Mobility Profile. Then i create a TCT Device (IPhone dual Phone) and try to configure a Mobility Identity.
I can save the Mobility Identity whe i do not select a Mobility Profile.
When i select the previous configured Mobility Profile a get following error Message when i try to save the configuration:
Update failed. TypeDbErrors.gen25288 |
i did not found anything which give a hint what could be a reason. I get this Message with 9.1.1 and also after Upgrade to 9.1.1a
br Mike
