Hi Guys!!
I am trying to copy some TFTPs files from the my TFTP server (publisher) to my computer using a Linux server I have.
I am using the command.
admin:file get tftp term45.default.loads
Please wait while the system is gathering files info ...done.
Sub-directories were not traversed.
Number of files affected: 1
Total size in Bytes: 673
Total size in Kbytes: 0.65722656
Would you like to proceed [y/n]? y
and then writing the correct IP address, username and directory.
At the end CUCM tells me there was an error and I should see the configuration in the linux box.
Then I go to Linux.
#service ssh status
it tells me something about aes256-cbc and 3des-cbc errors.
I tried to add those cypher's using these link below.
steronius.blogspot.com/2014/10/ssh-no-matching-cipher-found.html
(also I am using #service ssh restart)
but nothing works.
Can someone one tell me how may I get the files from CUCM to my Linux Server? anyone that has the same situation... and successfully achieved to solve it?
as far as I know those Cypher's are not secure that is why Open SSH has disabled them, but it is a way to overcome this?
