CUCM 9.1.2 - Volume report for Translation Pattern
michael0627
Hello all,
I have a translation pattern going to a hunt pilot and need to find out the call volume of it.  If I just run a volume report on the hunt pilot, I only get results for when some directly calls the extension.  Is there a way to find the call volume that goes to the translation pattern?
Thank you.
James Hawkins
Level 8
Level 8
I do not know any way to report on that specifically. I would just create a second hunt pilot and point your translation pattern at that (or delete the translation pattern and use the number directly for the hunt pilot).
