01-20-2014 02:15 AM - edited 03-16-2019 09:19 PM
Hello All,
I was upgrading the cucm 9.1 cluster and my points are:
- there is not specific point for upgrading subsequent nodes - you are able to upgrade the subscriber only after the publisher finished instalation with this:
upgrade_install.sh|Initiated cluster manager to send updated publisher data to subscribers|<LVL::Info>
upgrade_install.sh|Upgrade Complete -- (0)|<LVL::Info>
- if you will follow the release notes and try to start upgrade after specific logs with the new product version, you will receive this information:
"The given directory was located and searched but no valid options or upgrades were available. Note, the system cannot be downgraded so option and upgrade files for previous releases were ignored."
Maybe one point for fixing the release notes.
Best.
Richard
01-20-2014 02:27 AM
Hi Richard,
what is the existing CUCM version and the desired version to be upgraded?
from the last point mentioned,It seems that you are not following the correct upgrade path.
regds,
aman
01-20-2014 02:31 AM
Hi Aman,
that was only patch to 9.1.2.11900-12 from 9.1.1.20000-5 so direct upgrade.
Richard
01-20-2014 02:44 AM
Hi Richard,
can u share the show version active from CLI or from GUI when u login in CUCM Application administration?
Also, please confirm which is the filename u are using for upgradation from below :
a. UCSInstall_UCOS_9.1.2.11900-12.sgn.iso
b. UCSInstall_UCOS_UNRST_9.1.2.11900-12.sgn.iso
regds,
aman
01-20-2014 02:49 AM
admin:show version active
Active Master Version: 9.1.2.11900-12
and the inactive part is:
admin:show version inactive
Inactive Master Version: 9.1.1.20000-5
R.
01-20-2014 03:05 AM
Hi Richard,
show version active shows the 9.1(2)SU1. This means CUCM is working on the desired version.
You would have done the switch over from 9.1.1.20000-5 to 9.1(2)SU1. Please confirm if I am correct.
I did not understand where is the problem.
regds,
aman
01-20-2014 03:09 AM
Hi Aman,
there is no problem with upgrade. The patch was installed successfully. But you are not able install subsequent nodes till the publisher finish the instalation.
No problem, no bug, that was only information, that the release notes say that you are able to start instalation, but the true is that no. You must wait.
R.
01-20-2014 03:27 AM
01-20-2014 03:32 AM
Hi Aman,
sorry, that was my mistake. The document was Upgrade guide and here is link:
Part upgrade a cluster.
R.
01-20-2014 03:47 AM
Hi Richard,
you are referring to Parallel upgrade
Did u check the most recent install log file?
You can only start upgarding other nodes in a cluster after u get the message in a Publisher
09:53:54 post_upgrade|PRODUCT_VERSION_DISPLAY is 9.1.2.11900-12|<:INFO> Search completed
this is what I can say.
regds,
aman
01-20-2014 03:51 AM
Yes. I checked the most recent log file from utils system upgrade status. But I was able to start upgrade on the subscribers after the publisher finished the upgrade.
R.
09-19-2015 07:14 AM
I confirm this.
I'm doing an upgrade right now from 10.0.1.10000-24 to 10.5.2.12901-1.
I saw the PRODUCT_TARGET, NAME and the other stuffs however I can only see the following message on the Subscriber :
"The version obtained from the name does not match the active or inactive version of the publisher. "
This is sad because Upgrade Guide is the most important guide in my opinion (Installation Guide is less important since the installation mayb not be directly on Production, however the Upgrades are done directly on Production platform).
The guide has to be pretty pertinent to the last character.
09-19-2015 07:32 AM
Hi Jaafar,
refer the discussion
https://supportforums.cisco.com/discussion/12586561/apply-patch-reinstallation-subscriber
regds,
aman
