does the CUPS 8.5 is compatible with the CUCM9.x ?
We're planning to upgrade a CUCM8.6 to 9.1. But don't want to upgrade the CUPS8.5.
will the CUP8.5 work with the CUCM 9.x?
i have not seen any document about the compatibility matrix, that why i have sent this post here.
Antra
Solved! Go to Solution.
No, the major and minor release need to match, you HAVE to upgrade to IM&P 9.1.
Starting with 9.x, the CUCM and IM&P versions need to be aligned at the x.y level.
thank you for your answer
So the 8.5 won't be compatible (won't work) with the CUCM9.1 after upgrade of the CUCM.
Thank you
Antra
