05-27-2014 08:02 AM - edited 03-16-2019 10:54 PM
does the CUPS 8.5 is compatible with the CUCM9.x ?
We're planning to upgrade a CUCM8.6 to 9.1. But don't want to upgrade the CUPS8.5.
will the CUP8.5 work with the CUCM 9.x?
i have not seen any document about the compatibility matrix, that why i have sent this post here.
Antra
Solved! Go to Solution.
05-27-2014 08:08 AM
No, the major and minor release need to match, you HAVE to upgrade to IM&P 9.1.
Starting with 9.x, the CUCM and IM&P versions need to be aligned at the x.y level.
05-27-2014 08:08 AM
05-30-2014 03:20 AM
thank you for your answer
So the 8.5 won't be compatible (won't work) with the CUCM9.1 after upgrade of the CUCM.
Thank you
Antra
