06-23-2013 01:55 PM - edited 03-16-2019 06:02 PM
Hello
Please find the attached,
Is it possible for lower standard to borrow from higher standard,
i mean to say can Enhanced count can borrow from CUWL Standard count license ,
What can be done to get rid of the insufficient error.
06-24-2013 01:30 AM
Hi Jack,
I was just refering Admin guide of Borrow and Loan of License works.It says Enhanced license cannot borrow from other license types.If enhanced license are available,it can loan.
regds,
aman
06-25-2013 11:07 AM
I have only connected 100 phones and i have available more than 100 license then why it is showing me this error.
06-25-2013 11:12 AM
You need to check your licensing DLU requirements for the phones. Some require 4 units while others require less. So if you had for instance 100 7962s you would need 400 DLUs to be able to handle that many since each 7962 takes up 4 units within the license(s).
06-25-2013 11:23 AM
Well,
This error is recently by connecting the 7975 phones in the network, can you tell me the DLU requirement for 7975 phones and these phones come under enhanced category.
06-25-2013 11:34 AM
Based on CUCM 8.6.2 I see a that 5 licenses are used for each 7975 on the system. So if you have 100 of those you need 500 DLUs. On your CUCM go to System -> Licensing -> License Unit Calculator for all the values.
06-25-2013 11:46 AM
Hello
The output what i showed you is from ELM and my CUCM is 9.1.
06-25-2013 08:56 PM
Hi Jack,
You run the User Count Tool UCT.This can be downloaded from Cisco site.
regds,
aman
06-25-2013 11:50 AM
Ok, the version doesn't matter, you need to check the licensing requirements for those phones on your system regardless of what version you are running. 100 licenses does not necessarily mean 100 phones. It is based on the phone or device.
06-25-2013 09:26 PM
From the snap shot provided it seems that there is insufficient Enhanced license types .
Shyam
