03-01-2014 12:06 PM - edited 03-16-2019 09:58 PM
Hello ,
i am have cucm9 . i can not login user account when user is having Active Directory PAssword '''Error : username or password is incorrect ''
while i can login successfuly if i change the end user password on CUCM.
simply not working with Active Directory Passwords
please Advise .
Solved! Go to Solution.
03-01-2014 12:33 PM
If the user is ldap integrated and you have ldap authentication configured you would not be able to change the password in CUCM, can you make sure ldap authentication is turned on?
Chris
03-02-2014 12:11 AM
Hi Aslam,
To add more, prior to CUCM 9,
a. User cannot be added to CUCM, if LDAP was enabled.
b. ENd user need to be defined on LDAP and then, do the synchronisation.
But with CUCM 9
a. Administrator can have both Local and LDAP synced users.
b. we can modify local users and roles assigned to LDAP users.
c. further, administrator can also convert LDAP user to local user.
d. Under the End Users page , u can differentiate Active Local users and Active LDAP synchronised users.
regds,
aman
03-01-2014 12:33 PM
Chris
03-01-2014 12:41 PM
thanks for reply Chris ,
i will check and update you .
03-02-2014 12:11 AM
Hi Aslam,
But with CUCM 9
regds,
aman
