04-10-2014 07:53 AM - edited 03-16-2019 10:26 PM
Hello There,
When attempting to “Modify Button Items” on a Device Profile, once you click the button and the pop up window comes up, the main page refreshes as a Cisco 9951 rather than the Device Profile it should be.
I has been checked 9.x three difference version all have same behaviour. I am not sure is it bud or something else.
I am attaching the Screen shot as a reference.
Is any one know the reason or face the same issue.
Ryhan
Solved! Go to Solution.
04-10-2014 08:29 AM
Hi Ryhan,
Just to add a note to the good tips from my buddy Aman (+5 )
Can you check this bug;
04-10-2014 08:22 AM
Hi Ryhan,
Did u try changing the browser?
regds,
aman
04-10-2014 08:26 AM
I tried with Different Browser but no luck mate.
Muhammad
04-10-2014 08:37 AM
Hi Rob,
You are simply Gr8.
I was trying to look for the bug but could not.
regds,
aman
04-10-2014 08:29 AM
Hi Ryhan,
04-10-2014 08:46 AM
Thanks Rob,
You save my day.
Really appropriate the effort of Rob and Aman.
04-10-2014 09:30 AM
Hi Ryhan,
You are most welcome my friend
Cheers!
Rob
