CUCM 9.X Licensing
Leonardo Santana
I installed CUCM 9.0 but in dont the licenses yet, its possible to register  any IP Phones without licenses now?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
9 Replies 9
cvirgo
9 requires the use of the ELM for UC apps to register to for licensing.
Ayodeji Okanlawon
CUCM 9.0 Cluster - Enterprise Licensing
CUCM version 9.0 provides a new licensing mechanism called Enterprise Licensing Manager (ELM). ELM comes as a service which runs on a CUCM node in the cluster. It provides a single place of licensing control for the entire system. It includes the user licensing for CUCM, CUCM IM & Presence, Cisco Unity Connection
You need to install the Enterprise License Manager. You will see this on the media you have used to install the servers.
You can install on the same node as the publisher or install it as a seperate server. Once this is done your first task is to add the product instances aka server components such as CUCM clusters or Cisco Unity Connection servers to the inventory. Select Inventory -> Product Instances from the left navigation menu. After a fresh install there should not be any entries. Choose Add from the top row to add your CUCM instance
The Test Connection button provides the means to verify that all parameters have been entered correctly
The Product instances now show a new instance of CUCM that is not yet synchronized (Synchronization Status column).
Select the row with your cucm and press the Synchronize Now button to initiate the the synchronization
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hello i dont have licenses yet,
I sync Publisher, but Subscriber is falling folow the error message:
Test Connection Failed. The Enterprise License Manager client service on the product is not responding.
Leonardo Santana
Leonardo Santana
Rob Huffman
Hi Leonardo,
You may be seeing this bug;
CSCua31571 - UCM subscriber add - ELM client crashing
Description
Symptom:
Conditions:
While trying to add a UCM subscriber as a product to ELM, the ELM client is crashing.
The ELM client log is shown below:
2012-06-04 14:26:56,761 INFO  [http-bio-443-exec-20] ProdState.setCurrentState - *** State change: UNREG --> REG_SECURE
2012-06-04 14:26:56,761 INFO  [http-bio-443-exec-20] ProdState.persist - Persisted the state data
2012-06-04 14:26:56,762 INFO  [http-bio-443-exec-20] RegisterELMHandler.registerELM - Invoking plugin::registerElm() - UCM
2012-06-04  14:26:56,762 INFO  [http-bio-443-exec-20] CucmPluginImpl.registerElm -  Received this ELM NODE during registration:bldr-vcm80.cisco.com
2012-06-04 14:27:00,567 INFO  [pool-2-thread-2] ElmClientContext.contextDestroyed - ==== ELM-Client servlet destroy ====
2012-06-04 14:27:00,567 WARN  [pool-2-thread-2] AbstractElmProductImpl.shutdown - NOT IMPLEMENTED!
2012-06-04 14:27:00,567 INFO  [pool-2-thread-2] ElmClientContext.contextDestroyed - ELM-Client servlet destroy done
Workaround:
No workaround
Details
First Found in:                          (1)
9.0(1)
Status:
Fixed
Last Modified:
Jan 02,2013
Fixed in:                          (4)
9.1(1.10000.11),9.1(0.98000.1),9.0(1.98000.228)
1.0(0.98000.42)
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Hello Rob i using CUCM 9.0.1.10000-37.
With Publisher works, but with sub i receive this error.
An i dont see the version i running at Fixed in.
Leonardo Santana
Leonardo Santana
Definitely make the move to 9.1.x since 9.0 has documented bugs and 9.1 is available now for download.
Rob if i not add the subscriber on ELM i cannot licensing him correct?
Leonardo Santana
Leonardo Santana
Rob Huffman
Hi Leonardo,
You will need to add the Sub
I would either open a TAC case or try 9.1(1.10000.11)
which is available for download.
Cheers!
Rob
-The Clash
Hello Rob,
Thanks again i will do that.
Leonardo Santana
Leonardo Santana
