Walkthrough Wednesdays
3780
[CUCM 9.x] No dial tone when calling in
I have a fairly new setup with CUCM and CUC running 9.1 version. Calls are going to the CUBE via SIP trunk from the provider, then they get sent via another SIP trunk to the CUCM, which then forwards it to the Call Handler in CUC (for business hours and holiday reasons). CUC then redirects the calls to Hunt Group 600 to ring the required phones.
Now when the some makes a call to the system from outside does not hear any ringing. However if the person is to call a someone's phone directly then the tone is there. DDI and main number use the same Route Pattern for translation and I have the outside dialtone ticked on the CUBE config as well as the Hunt Group.
Am I missing something?
1 ACCEPTED SOLUTION
On the trunk you can assigned a Media Resource Group list and in this list is a Media Resource Group that contains certain resources like Conference, MTP, MOH and ANN.  ANN=Annunciators.  MRGL can be assigned at the trunk level in this case or device pool.  My question has a MRGL been assigned to either place and if so does it contain the CUCM
Annunciators resources?
24 REPLIES 24
kelvin.blair
Contributor
What does the cube dialpeers look like?  You might be needing this on the voip dialpeer, but without seeing your dialpeer configuration for these calls it might be hard to tell.  You can try this and see if it works.
progress_ind setup enable 3
progress_ind progress enable 8
Hi Kevin,
This is my config of the dial-peers.
dial-peer voice 1 voip
description **Incoming Calls**
destination-pattern 441525......
session protocol sipv2
session target ipv4:192.168.13.101
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte sip-notify
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 10 voip
description **Outgoing Calls**
destination-pattern 0.T
session target sip-server
voice-class codec 1
no vad
dial-peer voice 2 voip
destination-pattern 441908787...
voice-class codec 1
no vad
dial-peer voice 100 voip
description **Inbound dial-peer for Outbound calls**
incoming called-number 0.T
voice-class codec 1
no vad
dial-peer voice 101 voip
description **Outbound Emergency calls**
incoming called-number 0...
voice-class codec 1
no vad
Also, what you suggested made no difference.
Try using the commands I suggested on your incoming dialpeer.  If that is unsuccessful, please provide a sho run excluding any passwords.  Also, please provide the following debug's:
debug ccsip messages
debug ccsip calls
debug voip dialpeer inout
Please see attached debug. Thanks for your help so far but the commands for DPs didn't do any difference.
Покажи dial-peers pots
У меня только sip. Проблема устронена, спасибо.
Here is the show run with sensitive info removed.
First Suggestion:
Your matching incoming dialpeer of 10 and outgoing dialpeer of 2.
Dialpeer 2 add
incoming called XXXXXX <<<--should match destination-pattern
see if that helps..
provide debugs again if no go..
Sorry, makes no difference.
Here is the debug. Many thanks
Going out on a limb considering i can't look at your CUCM trunk configuration..
On your SIP profile in CUCM, do you have disable early media 180 checked?  try checking this to see if it helps or unchecking it. One thing that is really bothering me as well is this statement on the dialpeer to CUCM.. By default CUCM is delayed offer.
voice-class sip early-offer forced is not needed to CUCM.  It wasn't until 9.X that early offer is supported, but you need
Hi Kevin,
Sorry but none of these seem to make any difference.
1) I tried checking "Disable Early Media on 180" and making a call in, nothing - just silence but the internal phones ring.
2) Then I tried taking out "early-offer forced" as well which made no difference either.
Do I need to have 2 dial-peers on the CUBE, one for accepting the call from the VoiP provider and the second one for passing this call to the CUCM? At the moment I only have the one.
Do you have an MRGL assigned to the trunk that contains a ANN..?
Also, bind you sip traffic to a single interface.  this can cause issues as well.
For example:
voice service voip
sip
     bind control source-interface GigabitEthernetx/x
     bind media source-interface GigabitEthernetx/x
Sorry, no clue what the top bit means?
When I bind sip to Port-Channel 1.1 (which is my VLAN1), I get no audio when making a call.
Content for Community-Ad
Spotlight Awards 2021
