CUCM AD SYNC HAPPEN ONLY ONCE A DAY
Maleksalim
Hello Guys,
I have an issue with CUCM LDAP Synchronisation, it happen only once a day even if it's configured to be done each 6 hours.
Any Idea?
7 Replies 7
Sreekanth Narayanan
Hi maleksalim,
What is the complete call manager version? (a.b.c.ddddd-e)?
When did you start observing this?
Did this work before?
Sree
Hi Sreekanth,
the Version of CUCM is 8.6.2.22900-9
I observed that few months a go and I don't know if it worked before.
Hi maleksalim,
Could you attach a screenshot of your problem here?
Sree
Also please send me the output of the following commands:
run sql select * from directorypluginconfig
run sql select * from directorypluginschedule
Rob Huffman
Hi there,
Just wanted to look at this 8.6.2 bug in addition to the good tips from Sreekanth (+5)
CSCuf59031
LDAP SYNC NOT UPDATING  "Next Re-sync Time"
Symptom:
When a customer uses 6 hour schedule to have a  directory sync we would see that the "Next Re-Sync Time" value on the  web-page (under LDAP Directory configuration) does not change  periodically after every sync.
The LDAP syncs would work fine but there might be one or two LDAP Syncs that can get skipped.
Conditions:
CUCM version 8.6.2
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
Good catch there Rob! That seems to be the issue .
CSCue47475 is the original defect that was opened for it.
maleksalim, you would need to upgrade the CUCM to 8.6.2.24081-1 to fix this. That's an ES and only TAC can provide this.
This is also fixed in 9.1.2.10000-28 and 9.1.1.21017-2.
Sree
Thank you Rob , Sreekanth (+5)
I think the bug is the issue, I will check in other cluster if it's the same thing
