Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM Administration Webpage Access very slowly
Nguyen KeThuc
Beginner
Beginner
Hi all,
I have some Cisco UCM servers  version 8.5.1.10000-26. . There are few IP Phones. But Administration Webpage Access is very slow in publisher server. I also checked the CPU and Memory, they are fine. Anybody help me?
Thuc
ronpatel
Collaborator
Collaborator
HI
You can restart tomcat service and issue will resolve.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj50884
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Joseph Martini
Try and run a "utils diagnose test" from the command line and see if you gete an hprof file created by running "file list activelog /tomcat/logs/ date detail".  If you see one of those open up a TAC case and we can analyze it to see what's going on.  Alternatively the Cisco Tomcat logs collected through the real time monitoring tool are useful to look at what is accessing the web service in the localhost_access log files.  If you do end up opening a TAC case try and have these items ready for the engineer along with a time stamp of when you noticed the web page being slow.
- Event Viewer - Application Logs
- Cisco RIS Data Collector Perfmon Logs
- Cisco Tomcat Logs
Hi Ronak ,
I already restarted Tomcat service, but the issue still happens.
Thuc
Try to upgrade to laster release of 8.5 and issue will get resolve.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Recognize Your Peers
