10-29-2015 09:51 AM - edited 03-17-2019 04:44 AM
Hi All,
I'm about to integrate our AD into CUCM for it's directory.
Ideally I'd like to do a test run, but encountered many problems when trying to login to a vm clone of CM so I sacked it off.
So now I just want to go for it, but am concerned how disruptive it's going to be.
I have created a user in AD for every phone within the company.
My CUCM users have a user ID of their directory number, and then are named correctly within their name fields. The majority of my AD users are people with first names and last names configured in their account. Will CUCM match them up, with the USER ID being the directory number and not their name?
Solved! Go to Solution.
10-29-2015 05:15 PM
I dont think it will match them up. because your User ID's will still be unique, whether they are local User ID's or imported through LDAP.
whatever you decide to do, make sure you snapshot your VM, to be on the safeside.
10-29-2015 10:19 AM
Assuming CUCM 9.x, worst case scenario is that you cannot map the field that has the same value as your current userIDs and they'll remain local users + the new synced LDAP users.
If below 9.x, then you'll wipe them all and replace only with LDAP users.
the options for userID are limited to 5-6 LDAP fields, and you can only choose from between those.
If they do match, they'll simply be updated as LDAP users and synced with your LDAP info.
10-30-2015 04:37 AM
Yes, is 9.1.2.
I like the snapshot idea. I will take one on Monday and do the integration and see what happens!
Thanks guys
10-29-2015 05:15 PM
