CUCM and IPOSE SIP TRUNK Configuration
EngMajdi
Hi ...
I need an assist me in attempting to complete a SIP call to a Cisco Call Manager (CUCM11.5) from an Avaya IPOSE 11.1. I am able to successfully call from any Avaya IP Phone on the IP Office to any extension on the CCM, but I cannot complete any calls from the CUCM to the IPOSE. Here is a sample sys monitor output from a failed call.
Below is Cisco’s feedback as well, with the conclusion in the last line in red.
  1. The CUCM sends the sip:32091846@10.234.11.1:5060 SIP/2.0 to the AVAYA server.
    INVITE sip:32091846@10.234.11.1:5060 SIP/2.0
    Via: SIP/2.0/TCP 172.20.101.21:5060;branch=z9hG4bK2d119759fb4dc4
    From: "jabber Test" <sip:9712222@172.20.101.21>;tag=29264673~a3e24dc8-8444-4488-bc75-cbe3658de430-35285859
    To: <sip:32091846@10.234.11.1>
    Date: Mon, 20 Mar 2023 10:58:43 GMT
    Call-ID: 2c917900-41813c63-20f56d-156514ac@172.20.101.21
    Supported: timer,resource-priority,replaces
    Min-SE: 1800
    User-Agent: Cisco-CUCM11.5
    Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
    CSeq: 101 INVITE
    Expires: 180
    Allow-Events: presence
    Supported: X-cisco-srtp-fallback,X-cisco-original-called
    Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP;x-cisco-qos-tcl=true
    Session-ID: 55aa935f00105000a0007064823698aa;remote=00000000000000000000000000000000
    Cisco-Guid: 0747731200-0000065536-0000065185-0358945964
    Session-Expires: 1800
    P-Asserted-Identity: "jabber Test" <sip:9712222@172.20.101.21>
    Remote-Party-ID: "jabber Test" <sip:9712700@172.20.101.21>;party=calling;screen=yes;privacy=off
    Contact: <sip:9712700@172.20.101.21:5060;transport=tcp>;video;audio;+u.sip!devicename.ccm.cisco.com="BOT2222";bfcp
    Max-Forwards: 13
    Content-Length: 0
    2- Avaya respond to CUCM with 100 trying
    SIP/2.0 100 Trying
    CSeq: 101 INVITE
    Allow: INVITE,ACK,CANCEL,OPTIONS,BYE,INFO,REFER,NOTIFY,UPDATE
    Supported: timer
    Server: IP Office 11.1.2.3.0 build 47
    To: <sip:32091846@10.234.11.1>;tag=ffe4ad8ebbe4dfe2
    Content-Length: 0
    3- Avaya respond to cucm with 503 Service Unavailable
    SIP/2.0 503 Service Unavailable
    CSeq: 101 INVITE
    Supported: timer
    Reason: Q.850;cause=88;text="Incompatible destination"
    Content-Length: 0
    4- ACK sip form the cucm
    ACK sip:32091846@10.234.11.1:5060 SIP/2.0
    Max-Forwards: 70
    CSeq: 101 ACK
    Content-Length: 0
why its respond with 503 error ?
CSeq: 101 INVITE
Supported: timer
Reason: Q.850;cause=88;text="Incompatible destination" >>> This is the issue. Find out why avaya send Incompatible Destination.
Response Signature
Anyone have an answer for this? I am having the exact same issue.
As @Nithin Eluvathingal has already stated: Check with the Avaya technician
The error is coming from Avaya, so what do you want to troubleshoot on the CUCM side?!
Avaya needs to say, how they want the INVITE.
Come on guys, this has nothing to do with any technical stuff at all.
If B says "I don't like what A is sending", without mentioning why he doesn't like it, there is nothing A can change.
In the OP output the invite is sent with both video and voice capabilities. That could be what is causing the Avaya side to send the incompatible message. Try adding the command voice-class sip audio forced on the dial peer(s) facing the Avaya system. For more information please see this document. Video Suppression
Response Signature
