CUCM and LDAP Integration
akoukis
Hello to everyone,
does anyone knows the minimal required attributes on MS Active Directory in order to import and sync a user to CUCM from MS AD LDAP integration?
On SRND of 11.X describes only the mapping between Unified CM User Field and Microsoft Active Directory.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/directry.html#74101
Best Regards
Anestis
Out of curiosity I just tested this. Looks like last name is required, but not first. I created a user with no first name and was able to sync. See attached.
5 Replies 5
Brandon Buffin
The answer would depend on the existence of a custom filter applied to the LDAP directory config in CUCM. For example, if I have (Company=*) in the custom filter, the user would need a company in AD in order for the sync to happen. Without a filter, CUCM will sync all users within the LDAP User Search Base. Beyond that, the user would need the LDAP field configured to map to the CUCM user ID (System > LDAP > LDAP System > LDAP Attibute for User ID). There are no other required attributes as far as I know.
Brandon
Hi to all,
thank you every one about the feedback, I will give my 5 points to Brandon because he spend some time to test it and give us a response with an output.
Thanks again
Anestis
pqueued
Absolute minimum is First and Last name. Without a LDAP filter whatever your search base is after sync will suck in all users that have at minimum First and Last name attributes.
I stand corrected, I guess it's out of habit that the first name is kinda a given however if last name is left out sync for that user will fail. Corresponds with mandatory fields in end users.
