06-09-2011 07:26 AM - edited 03-16-2019 05:22 AM
Hello gurus
Is above-mentioned feature supported by latest versions of CUCM itself or by IP Phones WITHOUT any additional equipment(like routers + TCL/IVR programming or XML applications)?
Solved! Go to Solution.
06-09-2011 07:31 AM
No, that's no something you can do with just CUCM and phones.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-09-2011 07:31 AM
java
06-09-2011 11:09 PM
Thanks for a quick answer!
