1195
2044418Puts
Beginner
CUCM - Assign dn's to multiple phones
This may sound as a very stupid question, but I just cant seem to find the option. How can one assign a DN to multiple phones? I think I'm overlooking something  ...
Thanks!
2 REPLIES 2
Efrain Hernandez
Hi, what is youd CUCM's version? for 5.x, 6.x, 7.x easiest way is to serach DN then there is a field bellow that shows devices assotiated or you can add the deivce then assotiate same DN. With 4.x just add the same DN to the device.... does this help ?
2044418Puts
Beginner
Okay, I just figured this one out. Just create a new DN with the same number and within the same partition. Then it's working fine.
Create
Recognize Your Peers
Content for Community-Ad
