11-20-2012 01:04 AM - edited 03-16-2019 02:17 PM
Hi guys,
I am working with a cluster over WAN. So it is a single CUCM Cluster over WAN. My PUB and 2xSUBs are in HQ and 2xSUBs in BR1.
I have auto-reg enabled with the range of 51000-51099 numbers on HQ SUBs for HQ phones.
Now, I need to enable auto-reg on BR1 SUBs with the range of 61000 - 61099 for BR1 phones.
Theproblem is all my phones regardless the location get the same range, that's 51xxx.
Anyone knows how to do it site-specific so that BR1 gets 61xxx? Your input is much appreciated
Earliest thanks
11-20-2012 06:45 AM
Are you pointing to that server as the TFTP???
Or are you pointing to the one with 51XXXXX??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-20-2012 06:50 AM
Auto-registration can only be enabled on one server as there should be no need to enable it on others. Simply adjust the DN range on the existing server that is setup for auto registration. All you need to ensure is (which should be the case) that the DP referenced by device defaults page uses CUCM group with auto registration on and server in that group is setup for auto registration.
HTH,
Chris
11-20-2012 01:17 PM
+5 chris.In addition to the excellent tip from chris, Ensure that the server that is enabled for auto registration is the primary server in the cucm group
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
