06-18-2013 05:56 AM - edited 03-16-2019 05:56 PM
Hi Everyone,
I have just stumbled upon an idea:
What if a BACD script can be setup in a SIP Gateway to route CUCM hunt-pilot instead of ephone-hunt group
diagram
PSTN-->SIPGW-->CUCM
It's not possible to route an extension connected to CUCM
for example
ephone-hunt 1 sequential
pilot 2945555
list 5648568
dial-peer voice 9889 voip
destination-pattern 2945555
session protocol sipv2
session target ipv4:10.177.85.66
voice-class codec 1
dtmf-relay rtp-nte
no vad
This will not work, because an error will stop it.
What if instead of buying an expensive contact center, a simple BACD that connect's to CUCM without using CME. I have never done this before, it will be interesting. Is it possible?, please comment
Auto Attended # = 294-5555
Group 1 = 294-6001(Hunt Pilot Configured in CUCM)
Members = 6001,6002,6003
Group 2 = 294-6002(Hunt Pilot Configured in CUCM)
Members = 6011,6012,6013
Group 3 = 294-6003(Hunt Pilot Configured in CUCM)
Members = 6021,6022,6023
PSTN Caller dials 294-5555
PSTN-->SIPGW-->BACD-->Rerouted>-->CUCM-->Hunt Pilot-->Hunt List--> Members-List
CUCM = 10.177.85.66
SIPGW= 10.10.254.3
Configuration
dial-peer voice 222 voip
service aa
session target ipv4:10.10.254.3
incoming called-number 2945555
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3302 voip
destination-pattern 2946....
voice-class codec 1
dtmf-relay rtp-nte
no vad
service aa flash:app-b-acd-aa-3.0.0.2.tcl
paramspace english index 1
paramspace english language en
paramspace english location flash:
param service-name queue
param handoff-string aa
param aa-pilot 2945555
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 700
param voice-mail 2945594
param max-time-vm-retry 2
param number-of-hunt-grps 1
param dial-by-extension-option 4
param second-greeting-time 60
service queue flash:app-b-acd-3.0.0.2.tcl
param number-of-hunt-grps 3
param aa-hunt1 2946001
param aa-hunt2 2946002
param aa-hunt3 2946003
param queue-len 15
param queue-manager-debugs 1
Solved! Go to Solution.
06-18-2013 02:32 PM
Unity Connection will alow you to build the IVR menus, but it will not allow you to queue a call. CUCM 9.X as previously stated can be combined with Unity Connection to build a menu and then queue the call.
HTH,
Chis
06-18-2013 06:41 AM
BACD is only compatible with CME, it will not queue to CUCM extensions.
As of version 9.0 CUCM does have basic ACD functionality that allows you to queue calls and play prompts just like BACD.
Chris
06-18-2013 02:21 PM
Thanks for the quick reply
but is it possible to do this using Unity connection?
06-18-2013 02:32 PM
HTH,
Chis
06-18-2013 05:09 PM
Actually you can queue a call with CUC, but the problem is, that while you wait, every minute or so, you'll be prompted if you want to remain waiting or if you want to leave a message.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-18-2013 05:30 PM
Java,
Are you referring to supervised transfers with call hold? I would not really consider that anything close to ACD queue.
Chris
