06-09-2014 12:05 PM - edited 03-16-2019 11:03 PM
Hi All,
I'm attempting to setup email alerts for successful/failed backups in CUCM. I currently have the mailserver configured using RTMT and have alerts enable for CiscoDRFFailure. I have 2 questions however...
1. - Is there a way to configure the alerts for CiscoDRFFailue to also report the successes. If not, how can I go about doing that? I see that there is an alarm for DRFBackUpCompleted, but i cant seem to find it for a custom alert (nor have I set up any custom alerts as of yet)
2. - How can I test mailflow for the alerts? I pretty sure I have everything configured correctly, but just want to make sure that if the alert is triggered, that I will in fact receive an email for it. I dont see a test connection or test mailflow option.
Any suggestions would be greatly appreciated! Thanks in advance all!
Tommy
06-11-2014 06:57 AM
Hi Tommy,
I'm not sure if its possible from RTMT to configure these alerts but you can configure notifications to be sent to a syslog server, you can do this via
CUCM Serviceability > Alarm > Configuration > Backup and Restore Services > Cisco DRS Master, from here you can enable the syslog server.
This will provide notification of both failed and successful backups.
As for testing if email is working i normally set up an alert against failed logins on CUCM and trigger that by entering the wrong password and waiting for the email to arrive.
Richard
06-11-2014 06:23 PM
Thanks Richardsimmons for the response. I think I got the alerts working ( and will be testing tomorrow completely. I'll definitely post back my results for anyone else with a similar question.
Also, email alerts testing the way you suggested worked great too! I wonder why a quick "send test mail" isnt included to ensure functioning correctly?
Thanks!
Tommy
06-16-2014 09:12 AM
Hi Tommy,
Glad to hear its now working!
It would be very helpful to have that option in RTMT, maybe it will appear in a future release.
Richard
