CUCM BE 6K 9.1 Licensing
I installed BE 6K 9.1 publisher and subscriber recently.
(after installation both servers showing the warning message which says that its running on demo mode)
Last week i added the license to ELM and the warning message on publisher node is gone but the warning message on subscriber is still there
Attached files are the screenshots of both publisher and subscriber.
i also attached the product instance of ELM in which i added primary nodes of CUCM and unity connection, its not allowing me to add subscriber node.
Thank You..
Dragan Ilic
Level 4
Level 4
If I remember correctly - when you activated your PAK how many nodes did you enter there? I think you should enter 2 - one for PUB and one for SUB.
BR,
Dragan
HTH,
Dragan
Brian Meade
Level 7
Level 7
You should only have the publisher added to ELM so that is working as expected.  The error message on the subscriber looks to be a possible dbreplication issue.
What does "utils dbreplication runtimestate" look like on the publisher?
