Cisco Community Designated VIP Class of 2020
259
Beginner
CUCM Call Routing. Order of partitions Vs Best Match.
Cube -- SIP trunk -- CUCM -- SIP Phones
Trunk CSS has 2 Pt
Css-inbound (in order of prioritization)
1 -pt-screen
2 -pt-DN
Pt-screen has translation pattern 75xx
pt-Dn has DN 7522 assigned to it.
Incoming call to 7522 should hit?
I was anticipating it should hit the first prioritized pt, but did not. Checked some documentation to verify best match will take over pt prioritization list in CSS.
What can be the other way to achieve this? I want a translation pattern to be triggered not the DN.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: CUCM Call Routing. Order of partitions Vs Best Match.
Order of the partitions in a CSS in ONLY used as a tie breaker when two or more DN/patterns are equally good matches, otherwise, best match routing is always used, no matter where the partition of the target is in the CSS.
java
if this helps, please rate
2 REPLIES 2
java
Participant
What are you trying to accomplish? That will help looking for a solution.
Please remember to rate useful posts, click on the stars below.
Content for Community-Ad
FusionCharts will render here
