12-05-2016 12:14 AM - edited 03-17-2019 08:51 AM
We have 3 E1 line on the same VG.
The 3 E1 line has different number
Number A
Number B
Number C
Each of these 3 E1 line is configured to be translated to the UCCX_ApplicationNumber(10899)
When I checked the CDR I can see only the number(10899)
I need to get the total number of inbound calls for the 3 numbers respectively. But as per checking the CDR I cannot see any field regarding the translation pattern.
For your asisstance
12-05-2016 12:35 AM
Hi Rahzby,
The Translation Patterns are not included in the classification of CDRs in CAR (CDR Analysis and Report) or in the CDR itself AFAIK, you can only obtain the fields for "Original Called number" and "Final Called number" but not a record about the translation. However, you can try a workaround that i suggested in one of the similar posts some time back
https://supportforums.cisco.com/discussion/11966361/find-calls-translation-patterns
Manish
12-05-2016 12:40 AM
Hi Manish,
Thank you for the confirmation. I have already a work around in mind. I just wanted to confirm if CUCM version 11.5 still does not support this feature.
Thank you for the clarification and reply
