CUCM Certificate Monitoring RTMT
Ajith Kumar
Can RTMT monitor certificate expiry of CUCM and alert ? If yes, please help me with how to configure it.
Thanks.
Andrew Skelly
Level 7
Level 7
You can do this directly from CUCM using Certificate Monitor.
Monitor Certificate Expiration
Use this procedure to configure your system to automatically send you an email message when a certificate is close to its expiration date.
Procedure
Step 1  From Cisco Unified OS Administration, choose Security > Certificate Monitor.
Step 2  In the Notification Start Time, enter a numeric value. This value is the number of days before you receive a notification through email.
Step 3  In the Notification Frequency, enter a numeric value and choose Days or Hours.
Step 4  (Optional)Check Enable E-mail notification, and then enter email addresses in the E-mail IDs field.
Step 5  Click Save.
Please rate helpful posts by clicking the thumbs up!
Hi Andrew,
Thanks for your suggestion!!!
Procedure
Step 5  Click Save.
Unfortunately that solution won't work for us because our monitoring system has pre-configured script which converts emails sent by RTMT (script only recognizes RTMT emails and no one know how to modify it) into SNMP traps and send to our SNMP platform. That's why I specifically asked about RTMT !!!
Have a look at this post, the OP in that came up with a solution for how to do this in RTMT.
https://community.cisco.com/t5/ip-telephony-and-phones/certificate-notification-rtmt/m-p/4062787#M387979
Response Signature
Thanks Roger !!!
