09-30-2016 12:31 AM - edited 03-17-2019 08:14 AM
I want to know calls history by a query.
It's possible?
I don't find appropriate tables.
More specifically, I search :
- All calls history
- All calls history of one number (if I know the previous query, it's not a problem...)
- All cals history of one number with statistic : how many time this number is called, on what periods (day, month, year), how many times he pick up the call ...
I have the database schema (https://developer.cisco.com/media/UCM10.5DataDictionary/UCM10.5DataDictionary.htm) but I don't find...
09-30-2016 12:39 AM
Hi Denis,
Have you checked the CDR Analysis and Reporting tool on CUCM which can provide this and lot of other reports as well.
Manish
09-30-2016 12:46 AM
Hi Manish,
Yes, I checked. But I must use SQL Query, because I want make statistic with other tool by using AXL SOAP Toolkil (or other) for retrieve data.
09-30-2016 02:11 AM
I found this table : tbl_billing_data
It's not referenced in the database schema... Why? => EDIT : ok... CAR database and CUCM database...
I have a first query but the history is not long :
run sql car SELECT callingpartynumber, originalcalledpartynumber, finalcalledpartynumber, lastredirectdn, user_id, datetimestamporigination, datetimestampconnect, datetimestampdisconnect, origmobiledevicename, destmobiledevicename FROM tbl_billing_data where originalcalledpartynumber='xxxxx'
