02-25-2013 12:10 AM - edited 03-16-2019 03:54 PM
I have a CUCM 8.6 running on VM which have a hard disk space of 500GB if i want to clone it with a smaller disk space so not everytime i do a backup it backsup 500GB, will i need new licenses for it to work after the clone?? or the current licenses will be working.
Mark
02-25-2013 05:48 AM
You will need to rebuild the VM with different OVA as resizing disk space is not supported on CUCM. You can use DRS backup/restore.
HTH,
Chris
02-26-2013 03:57 AM
Ok and will i need to generate a new license or the old license will work?
02-26-2013 04:28 AM
No, at least if you don't change any parameter during the installatio process.
The license gets associated to a license MAC, which is a 12 digit HEX value created by hashing the following parameters that you configure on the server:
•Certificate Information (Organization, Unit, Location, State, Country)
The ways to obtain the license MAC are as follows:
•Before installation, use the Answer File Generator (http://www.cisco.com/web/cuc_afg/index.html). When you generate the answer file, you also get the license MAC.
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
