CUCM Cluster different OVAs
de1denta
Level 3
Level 3
Hi All,
I'm currently working on a CUCM 11.x cluster that has a publisher and 3 call processing/TFTP subscriber servers. I've noticed that the publisher is running on a host using a 2.2Ghz CPU with an OVA configuration that supports 1,000 users (2vCPU, 6GB vRAM and 1 x 80GB disk) and the subsribers are running on hosts using 2.5Ghz CPUs with OVA configuration that support 2,500 users (1vCPU, 6GB vRAM, 1 x 80GB disk)
There are no performance issues (~1500 endpoints), however, I'm sure that I've read somewhere that the publisher OVA shouldnt be smaller than the subscribers. Is this correct and should this configuration be a concern?
Jaime Valencia
Read here:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/callpros.html#pgfId-1432138
Further down you find this statement, which goes back to the above link:
  • Cisco recommends using the same VM configuration for all nodes in a cluster. Mixing Unified CM VM configurations is allowed, but the cluster capacity might be limited. For more details, refer to the section on Mixing Unified CM VM Configurations.
java
if this helps, please rate
Jaime Valencia
Read here:
java
Thanks Jaime, I've read that and it make sense.
Appreciate your assitance
