04-15-2018 11:14 PM - edited 03-17-2019 12:37 PM
I am configuring Expressways for B2B calling. outgoing calls work fine. Incoming calls however are failing.
I see from expressway core call logs that the call in URi format is being transformed okay and is passed to CUCM. but in the logs i get 408 timeout. from CUCM logs I get no errors. I can see form the analyser that the CSS is correct and it passes the test. In the user directory number I have set the uri correctly.
I am wondering, on CUCM enterprise page do I need to set the 2 below fields? we have a split domain
external.com and internal.com what would I need to put in both fields? please do not refer me to any docs as I have read them and they are not clear on what is required or why
Clusterwide Domain Configuration
Solved! Go to Solution.
04-16-2018 01:20 AM
No, nothing resets. You dont need to add it to the two. Choose based on my description which field is more appropriate.
04-16-2018 12:22 AM - edited 04-16-2018 12:24 AM
It all depends. If the request that is sent to CUCM has a domain name then you should add that domain name to your CFQDN. You can add multiple domain names here but ensure it is a domain that is local to you. This is because any request to this domain will never be sent out to vcsc but will be processed locally by CUCM. The OTLD ( organisational top level domain) can be used if you share a domain both internally and externally because any request that matches this domain will be checked both internally and externally. CUCM will try to route calls for this domain externally as well. You can only have one domain name here
04-16-2018 12:30 AM
04-16-2018 01:20 AM
