CUCM Conference
ahautzmayer
1) how many People can be in an adhoc Conference Initiated from a phone at the Same time
2) how many people can Join an meet me conferenc ON the CUCM
THX
Leonardo Santana
Take a look on this link!
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a05confb.html
Leonardo Santana
Rate this if helps!
Leonardo Santana
*** Rate All Helpful Responses***
Leonardo Santana
Leonardo Santana
Rate this if helps!
Leonardo Santana
Thx
Bear in mind the figures from that link mostly refer to SW CFB, meaning only G711.
If you're using HW CFB it depends on PVDM2/PVDM3 and the codecs from dspfarm profile.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
