10-24-2015 11:12 AM - edited 03-17-2019 04:41 AM
Hi folks
Setting up a home lab with UCM and CUBE on a CSR 1000V, and having some issues.
Calling in or out of my system is not working currently.
Call flow is CUCM --> SIP trunk --> CUBE on 1000V --> SIP Trunk --> Through Sophos UTM --> ITSP (DIDLogic)
Exceptions are created and SIP override is on in Sophos UTM
I am receiving a 407 Proxy Authentication Required when I attempt to place an outgoing call. Inbound calls do not show up in debug results for debug ccsip all so I suspect this is an authentication issue.
Show run, and the debug ccsip all are attached
I've verified the correct dial peer is being hit. 192.168.1.7 is UCM, 1.10 is the CSR 1k, the outside address is my provider.
Thanks!!
Solved! Go to Solution.
10-24-2015 01:41 PM
Please modify what follows under sip-ua
authentication username xxxxx password 7 xxxxxx realm sip.ca.didlogic.net
with
authentication username xxxxx password 7 xxxxxx realm 70.33.227.122
Then, send the same debug
Carlo
10-24-2015 12:22 PM
Hi.
Can you please post a debug ccsip message only.
Carlo
10-24-2015 12:27 PM
10-24-2015 01:41 PM
with
Carlo
10-24-2015 01:50 PM
That fixed it! Outbound calling now working :-)
However, the call is incredibly low quality ..... Have a good enough connection, so think I have a few things to work on! Thank you so much!
Cheers
Seth
10-24-2015 02:29 PM
Hi Seth.
Glad that worked ;)
Please send now a debug ccsip message during a call .
Please rate useful posts and mark as answered the one you think solved your issue.
This would help others having your same issue
Cheers
Carlo
09-26-2017 03:01 AM
Hi Seth,
Just got my CSR1000V working both ways but have bad audio quality also. If I use same config but with a physical CUBE it works fine.
Did you manage to fix yours?
Rich
