CUCM,CUC,CUPS,CCX IN UCS SERVER
Hi Folks
We will move one customer to UCS servers
Questions:
1) CUCM and CUC must be at least 8.x version in vm
2) what about ccx and cup.Can we proceed in ucs with version 7.1.x for cups and ccx?
cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
3 Accepted Solutions
Harmit Singh
Jaime Valencia
1 Yes, 8.02) or later
2 No, you need to run versions supported for virtualization
I'd strongly suggest you to review the virtualization wiki
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
5 Replies 5
Harmit Singh
Jaime Valencia
java
java
Thank you both fro your answers
One last think
can i use ova file for version 9 and install first  cucm version 8.5 and then move to 9?
Where i can review these infos?
Cheers
cc
